skyliner34
Established Member
- Joined
- May 19, 2007
- Messages
- 450
- Reaction score
- 13
- Points
- 209
Ok heres my setup.
My Slim PS3 is connected to a HDMI switcher box and a optical lead from switcher box into my Sony VA555ES amp. Its a old amp, but I haven't upgraded as it sound brilliant. But of course over optical and amp age no HDMI I cant have the PS3 sending out TrueHD audio tracks from Blu-Ray.
I've tried manually setting up the PS3 sound output to tell it I cant decode dolby TrueHD, & DTS-HD by unselecting them from the audio output setting. But what the PS3 does then is send out the DTS, or Dolby Digital 5.1 & Dolby Plus to decode. Which works fine, but how do I get the PS3 not to do that and decode the HD ones onboard and send that out over HDMI as Linear PCM. Im sure the original PS3 which couldn't send the HD out over HDMI decoded them on the PS3 and sent it out.
Ive tried changing the BD audio to Linear PCM instead of bitstream and it sends out multichannel PCM, but I have no bass, its like the .1 audio has disappeared.
Help!?
Help!?
