PS3 AV Cable causes Electric sparks
Discussion in 'Cables & Switches' started by John K31, Apr 11, 2016.
  1. John K31
    John K31
    Apr 11, 2016
    NY
    i recently bought this PS3, but it seems to be causing electric sparks in "AV in" points when it's pluged to the TV and shutsdown the circuit breaker, however when i unplug the AV cable from the TV and plug the PS3 again all works fine, could the problem be in the AV cable or the PS3 or the TV ? i'm really confused about what to do.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,786
    The Borders
    +3,290
    Tricky to follow your notes.
    Which AV points are you connecting to?
    You then say you plug the PS3 back in and all is OK - is that to the same or a different Input on the TV?
    Power - are the TV and PS3 connected to the same power socket?
    PS3 - what is its history and have you checked it's power cable for damage/correct wiring?
    Joe
