nigel77
Established Member
I am going to buy a PS3 to use as a blu-ray player but I'm concerned that the audio output provided by the optical connection will be limited to just standard DD5.1 or DTS 5.1
Does the optical out support any of the new high def codecs such as dolby digital HD or Plus or DTS HD or does the digital optical output not have sufficient bandwidth. to support these formats.
is there any output on the PS3 that will plug into my Denon 2805?
Nigel
Nigel
