PS3 Audio Cutting Out Problem
Discussion in 'Playstation Forums' started by grantdp, Feb 2, 2009.
  1. grantdp
    grantdp
    Nov 11, 2008
    Ipswich
    My ps3's audio cuts out in milliseconds frequently. The picture remains fine when the audio cuts out.
    It has always been connected to my tv (Samsung LE37A686) via hdmi i haven't used the av connector yet.
    Anyone else has this problem? or has anyone got any ideas how to fix this?
    many thanks
    grant
  2. sykotik
    sykotik
    Sep 8, 2008
    7,097
    co. durham
    +2,267
    just a thought ...
    try pulling out the cable and putting it back in agian....
    try resetting your sound output from the ps3...
    try an other cable ???
    do you have an amp/hi-fi with an optical input?
    you may want to try sending the sound thro that way to seen if it's still breaking up!
    andrew
  3. grantdp
    grantdp
    Nov 11, 2008
    Ipswich
    Thanks for the quick reply, I'll have a go tonight and let you no. I only have the av cable spare with the ps3 so will try that. Do you think it will be worth trying another hdmi lead?
    Grant
  4. sykotik
    sykotik
    Sep 8, 2008
    7,097
    co. durham
    +2,267
    i heard you can pick up a cheap hdmi cable from one the cheap supermarkets
    (lidl or aldi supermarkets) cant remember which one...
    but there only a few quide , so might be worth a try or even ask one of your mate's if there have one to lend..
    andrew
