PS3 and Sky HD so wot 40incher is it for me?
Discussion in 'LCD & LED LCD TVs Forum' started by Del Boy Smiffy, Sep 15, 2007.
Tags:
  1. Del Boy Smiffy
    Del Boy Smiffy
    May 4, 2004
    6,531
    Yeovil
    +418
    :thumbsup:
    Have around the £1000 mark to spend.
    Want the best possible picture from Bluray/PS3 and sky HD for the money.
    Can go higher would like to go lower.:rotfl:
    All advice would be most appreciated especially from these that have the set up simular to mine(PS3 and Sky HD)
    Oh and links to cheapest prices too please.
  2. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    For little more the Samsung LE-40F86!Check first post of its thread for prices
  3. Spoonablehippo
    Spoonablehippo
    Sep 27, 2006
    1,604
    Rochester, Kent
    +226
    The Sony 40X2000 is a superb LCD and can be had for £1250.
    I know it's above your budget but it's worth the stretch! :)
  4. Del Boy Smiffy
    Del Boy Smiffy
    May 4, 2004
    6,531
    Yeovil
    +418
    Any more input?
  5. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    new sharps coming soon
  6. Xabi17
    Xabi17
    Aug 9, 2007
    414
    +16
    Check out the Sony KDL-40X2000, for a little over 1k but if that's too much then the W2000 should work for you as well.
    Panasonic LXD700? I'm not sure, I've heard some stuff about this...don't know if it'd suit.
  7. jsb2001
    jsb2001
    I AGREE !
    if you can stretch your budget, the x-series is well worth it. It is due to be replaced soon so prices are low (around £1300 from what i can find)
    http://www.teleworldplc.com/model.asp?Detail=Yes&ModelID=178
    If you need to be under the £1000 - then the kdl40w2000 is currently a bargain at about £835. Again it is being replaced, so prices are cheap.
    http://www.teleworldplc.com/model.asp?Detail=Yes&ModelID=177
    with sky HD and a PS3, it makes sense to go for the full HD 1080 panel, that will give you the best picture when watching blu-ray.
  8. Lewis123
    Lewis123
    Feb 13, 2006
    512
    28
    Shoreham-by-sea
    +52
    Also, the Samsung M86/87's are also quite nice. :)
  9. thej
    thej
    Apr 6, 2005
    330
    London
    +26
    I'd be interested in any input for this.
    I'm currently looking for a new TV. Looking at 50", therefore know that SD is never going to be great so quality at that level is a non issue. I want 1080p as it's primary use will be Blu-Ray and HD DVD movies.
    I figure LCD over Plasma as I'll be gaming on it too.
    Samsungs seem to get a lot of praise when they aren't faulty!
    Cheers.
  10. Del Boy Smiffy
    Del Boy Smiffy
    May 4, 2004
    6,531
    Yeovil
    +418
    Any more input before the weekend purchase?
  11. mikejones
    mikejones
    Aug 29, 2007
    22
    3
    +6
    Toshiba 42Z3030D - similar specs to the new top of the rangre sony's but at nearly a grand cheaper :thumbsup:
  12. the porter
    the porter
    Dec 15, 2004
    5,848
    lancs
    +1,593
    i think the samsung f86 is the 1 for you and im 90% sure its the you will buy if you can find one in stock;)
  13. daddycool
    daddycool
    Sep 5, 2005
    13
    Same question I was going to ask. Add in Xbox over component and Media center over VGA (or DVI?)
    What's all this I hear about "clouding" on the Sonys? I'd honestly rather get a Samsung but I want what's best. I'll go up to £1300 as well. I want the best TV I can get, I'd even go plasma....
