Hi i have the same router as you and it has a Hardware 2 level firewall built in, im surprised you didn't know that it had one, it's very secure as long as you leave it enabled you shouldn't have a problem.
i know i have a firewall built into my router but if i use the internet on my pc and my ps3 isnt on will this firewall be safe enough to use and will i not have to install a seperate firewall
You only need one firewall and the hardware firewall in your router is better then a software one. The firewall in your router is between your internet connection and your PC and PS3 so it acts as a barrier to both. If you're paranoid you could also have a software firewall on your PC but it's not really neccessary and would only eat up system resources.
At the very least use the built in firewall provided with Win XP (assuming that's what you're using) on your PC, however I'd suggest downloading and using the free version of zonealarm as that's more effective and will allow you to control what outbound communications are being sent from your PC.
Doing this won't cost you anything and is an additional layer of security.
At the very least use the built in firewall provided with Win XP (assuming that's what you're using) on your PC, however I'd suggest downloading and using the free version of zonealarm as that's more effective.
He has a hardware firewall built in to the router which is better than any software so he has no need to do that as moogle says it will just eat up resources and offer no better protection than what he has.
As software firewall is not very secure at all - the first thing a virus is going to do if it gets on your system is disable it. A firewall should not be running on the same machine that it's protecting - that's just basic network security.
upnp has the same issue - anything that gets on your box can blow holes in your external firewall which then makes it pointless. In that case it's a balance of convenience and risk.. do you want to have control over the firewall and know exactly what ports are coming in and out or do you implicitly trust the applications you run to not open unneeded ports and leave you vulnerable?
