PS3 and 428XD
Discussion in 'Plasma TVs Forum' started by roba666, Sep 15, 2007.
  1. roba666
    roba666
    May 28, 2007
    259
    Welwyn, Herts
    +15
    I'm a little bit confused.
    I've got my PS3 set to output 1080p and when I press info on the TV it's saying 1080p 36 bit.
    Is the TV receiving a 1080p ouput and downscaling it ? If so to what resolution?
    thanks
    R
  2. =adrian=
    =adrian=
    Jul 4, 2007
    17,114
    The Internet
    +7,433
    Yes.
    To the native resolution of your screen (1024x768).
    If I'm wrong I'm sure somebody will tell me.
  3. Peabo
    Peabo
    You should probably set the PS3 to 720p since that's what your TV's resolution is.
  4. fico99
    fico99
    Apr 20, 2005
    378
    +30
    This is not really necessary because the PDP-428XD can accept the following resolutions and have to scale them anyway:
    - 1080p60, 1080p50 & 1080p24
    - 1080i60, 1080i50
    - 720p60, 720p50
    - 576p50, 567i50
    - 480p60, 480i60
    Compare between 1080p and 720p and see what is best for you ;)
    Also make sure that you play Blu-ray movies @ 1080p24 :smashin:
    Cheers,
    Fico
  5. roba666
    roba666
    May 28, 2007
    259
    Welwyn, Herts
    +15
    Cheers,
    Fico[/QUOTE]
    Is that setting in Pure Cinema, Film Mode?
  6. fico99
    fico99
    Apr 20, 2005
    378
    +30
    No, that is a Blu-ray playback setting in your PS3 ;)
