PS3 amp and sound query
Discussion in 'Playstation Forums' started by Moiizer, Jun 13, 2008.
  1. Moiizer
    Moiizer
    Feb 21, 2008
    4,098
    2
    Batley, West Yorkshire
    +957
    hi guys
    im a bit confused with linear pcm and bitstream. i have my ps3 connected to my amp via optical.
    when linear pcm is selected i press select and its playing through dts-hd ma and when i select bitstream it just says DTS.
    i have read somewhere that when you have your amp connected via optical you should select bitstream, is this correct? as im no genious but i would have thought dts-hd is better than dts????
    im a bit of a novice so any help would be greatly appreciated :smashin:
  2. stuart1976
    stuart1976
    Apr 18, 2007
    1,082
    Timsbury, Bath
    +253
    You wont get the HD sound using Optical as it does not have the bandwidth to carry the HD format. The best you will get is DTS or DD 5.1
    You will need a receiver capable of handling the newer HD audio formats and connect the PS3 to the receiver using a HDMI cable.
    At the moment you are best using the bitstream setting with your Optical connection.
  3. hondavee4
    hondavee4
    Jul 22, 2006
    1,334
    +73
    plenty of talk here about this subject but basically the ps3 wont play the hd formats via bitstream, nor will it via optical as far as iam aware:rolleyes:
  4. hondavee4
    hondavee4
    Jul 22, 2006
    1,334
    +73
    beat me to it:rotfl:
  5. Moiizer
    Moiizer
    Feb 21, 2008
    4,098
    2
    +957
    thanks for your responses.
    so to get the hd audio i need to connect the ps3 to the amp via hdmi and not ps3 to tv via hdmi as i am now?
  6. stuart1976
    stuart1976
    Apr 18, 2007
    1,082
    Timsbury, Bath
    +253
    I've just had a look at your surround and it doesn't decode the HD Audio formats so it wont matter if you connect by HDMI or Optical as the best you will get will be DTS or DD 5.1
    You are going to need to upgrade to a new receiver that can handle the HD Audio formats if you want to take advantage of DTS-HD And Dolby TrueHD
  7. Moiizer
    Moiizer
    Feb 21, 2008
    4,098
    2
    +957
    thanks for that, did have a feeling it wouldnt but thanks for confirming :smashin:
