ps3 720p worth it ?
Discussion in 'Playstation Forums' started by uhal, Jan 30, 2009.
  1. uhal
    uhal
    Dec 31, 2008
    238
    +8
    ok so im getting a ps3 soon and would like any comments on blue ray on a 42 inch plasma screen in 720p ?
    shall i go forward with it ?? or wait til i get a 50 inch screen and 1080p.
    btw i have free access to limited blue ray and many games ?? along with my own intended puchases/cex.
    im also relatively impressed with dvd via scart rgb atm.
    any comments welcome
    steve
  2. Robothamster
    Robothamster
    Feb 28, 2008
    21,382
    5
    +14,356
    Do it. It'll look fantastic mate :smashin:
    Don't get too hung up on 1080p, you might notice a difference at those screen sizes but I reckon you'll be more than happy running a 42" 720p Plasma.
  3. bladedripper
    bladedripper
    Nov 26, 2007
    5,074
    Birmingham
    +1,529
    Yes the 720p plasma will be fantastic for BLU-RAY and gaming,well worth it.:smashin:
  4. GizmoTheMogwai
    GizmoTheMogwai
    Nov 6, 2008
    612
    Norwich
    +45
    I have a 32" Samsung 720p and the picture quality is ******* brilliant :D
  5. Samurai Weasel
    Samurai Weasel
    Feb 5, 2008
    199
    28
    Yorkshire
    +28
    PS3 on 42" Pio looks amazing. :) Unless you have really big screen and sit really close to it I doubt you'd notice that much difference between 720 & 1080p.
  6. sykotik
    sykotik
    Sep 8, 2008
    7,100
    co. durham
    +2,270
    dosent matter what hi-def spec your going to run it at ....
    it always going to look better than S-DEF:smashin:
    andrew
  7. Se777eN
    Se777eN
    Dec 28, 2006
    8,713
    2
    Southport
    +2,337
    I run all my games on 720p but am on a 32" :thumbsup: i just find it runs better and smoother .
  8. oj0
    oj0
    Jan 9, 2009
    745
    Southport
    +65
    If you already have a 42" 720p screen then its only the cost of a HDMI cable to make it look significantly better. If you're thinking 'should I go with 42 or 50' then that really is your decision entirely.
    I agree with others that the difference will be very little to the untrained eye and you will be significantly more impressed at 720p then you would with a standard cable!
    Enjoy whatever you choose!
  9. Deleted member 92943
    As long as your not on an SDTV, It should look fine
    SDTV, Yuk :p
  10. Zeromajor
    Zeromajor
    Feb 9, 2008
    4,419
    Btown
    +594
    40"+ go with a screen capable of 1080p - it'll be worth it in the long run when the next batch of consoles come out all running games at native 1080p (saving you going out and buying a new telly!)
    but anything under 40" for console gaming i'd say stick with 720p.
    as mentioned previously - if you're running a ps3 on an standard def telly, you need to upgrade. But it must be said that as enthusiasts, we're always going to say that.
    For example I have a mate who got a ps3 for xmas along with a HD tv. Last week I went round and he had the thing running at 576i when his tv was capable of displaying 720p. He didn't seem to mind....(I almost blew a fuse though :p)
  11. GizmoTheMogwai
    GizmoTheMogwai
    Nov 6, 2008
    612
    Norwich
    +45
    720p blew me away, in fact i'm getting a PS3 for Killzone 2 and all the beautiful Blu Ray movies :thumbsup:
  12. y2k
    y2k
    Jan 3, 2008
    3,300
    Banana Republic
    +291
    I would say the same, if you are debating this now before you have even bought the screen you will probably be thinking the same thing after you buy the TV and will might be wondering if you have made the right decision, so I would say save up a bit more and get the TV that you will be happy with whenever you buy it.
  13. Zeromajor
    Zeromajor
    Feb 9, 2008
    4,419
    Btown
    +594
    It's just like any technology, do I buy a cheap surround system which does the bare minimum, or do I save up a bit for one that will provide more value as it'll see me through more years.
    It's a recurring theme on avforums in general.
  14. cols
    cols
    Sep 5, 2008
    3,338
    Colchester
    +517
    indeed! Totally agree... "future proof" is an over-used and fairly meaningless term, but i'm of the opinion it's best to try to get something that'll last a few years at least. :D
    re the OP: what's the question? Go forward with getting a ps3 or go forward with getting a 42" 720p plasma?
    As said above, hd looks miles better than standard def, whether it's 720p or 1080p. General consensus seems to be that the difference between the two hd resolutions on 40" screens or less isn't that noticeable. :smashin:
  15. clc.sheff
    clc.sheff
    May 28, 2008
    3,560
    Steel City
    +1,874
    I've got a 720p 42inch plasma. Bit hard to say whether you should or shouldn't do it as there is more than one factor.
    If I'm honest my telly is a little too big for my viewing distance so I can detect a tiny bit of grain in the picture. If it was 1080p then I wouldn't. However I've got a pretty good plasma so I would have to trade quality for resolution (based on same price paid). I can still see a pretty resonable difference between blueray and upscaled DVD (which looks great compared to standard dvd) but the difference is obviously more pronounced on a 1080p set.
    For a 50 inch unless you are sat resonably far away I would probably recommend 1080p.
  16. uhal
    uhal
    Dec 31, 2008
    238
    +8
    Thanks for all the replys, finding your thread in the ps3 section is a bloody pain !!
    Anyway ive had the 42 inch plasma 720p for 2 months now and will be mounting on wall asap and getting an ebay ps3 40 gb for 169 soon after.
    was going to get a new floor but decided you cant watch that for long without getting bored !!! lol
    thanks again.
    steve
  17. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    Both ps3 and 360 are really 720p gaming systems neither can do much in the way of 1080p games and most games are 720p at best with many, many games actually being lower than 720p. Obviously for blu-ray the ps3 can display full 1080p visuals but at 42" unless your quite close you won't see the difference. 50" or projectors is where the true benefit of 1080p starts unless your really close.
  18. Jamie Smith
    Jamie Smith
    Jan 30, 2009
    Leeds, England
    720p and 1080p look identical on a Sharp Aquos 42" I have tested the ps3 out on.
  19. Jack-Deth
    Jack-Deth
    Sep 25, 2003
    6,354
    Ireland
    +1,341
    But what are you trying as source material? Are you trying games at native 720p and comparing with 1080p upscaled? Or are you trying something like WipeoutHD at 1080p and comparing with 720p. Or are you trying blu ray?
    I certainly notice significant improvements on my 42 Pana 1080p when watching native 1080p material at about 7 feet.
  20. Jamie Smith
    Jamie Smith
    Jan 30, 2009
    Leeds, England
    I was trying a native 720p game with 1080p upscaled. Sorry if there is a difference with games such as Wipeout HD, but most games I do not see a difference. I can't comment on blu ray as I am still buying DVD's and not blu ray atm.
  21. Jack-Deth
    Jack-Deth
    Sep 25, 2003
    6,354
    Ireland
    +1,341
    Its cool mate, I was not having a go, just asking :thumbsup:. You probably wont see much of a difference on up scaled games (ie native 720p > 1080p), but you probably will on WipeoutHD as its 1080p and 60FPS!!
  22. Jamie Smith
    Jamie Smith
    Jan 30, 2009
    Leeds, England
    I think that game is next on my list of purchases. I love a good futuristic racer. Never played Wipeout before though... always used to be a Nintendo guy before this generation of consoles, so I've played F-Zero but not Wipeout. I've heard it is really hard though.
    Edit: @ Jack-Deth, do you know how to stop oneself from being emailed everytime a reply is posted in a thread?
  23. Jack-Deth
    Jack-Deth
    Sep 25, 2003
    6,354
    Ireland
    +1,341
    Just un subscribe from the threads - I think its an option in the "control panel".
  24. Jamie Smith
    Jamie Smith
    Jan 30, 2009
    Leeds, England
    Thanks dude. I knew it was something to do with suscribing to threads as I've seen someone asking about this very same problem on a forum I'm a regular at. Just didn't know which part of the forum you access features like that, as I'm new to this forum. Hopefully I'll be a regular though, looks a nice, active forum this does.
  25. Jack-Deth
    Jack-Deth
    Sep 25, 2003
    6,354
    Ireland
    +1,341
    Actually, if you go to "Edit Options" which is halfway down on the left hand side of the "control panel" you can select to not be emailed any time you get involved in a thread.. :thumbsup:
  26. Jamie Smith
    Jamie Smith
    Jan 30, 2009
    Leeds, England
    Thanks for the quick reply. You are very helpful! :smashin:
  27. Jack-Deth
    Jack-Deth
    Sep 25, 2003
    6,354
    Ireland
    +1,341
    Its pretty friendly round here. There maybe the odd argument in a thread but we're usually a pretty chilled bunch..............Hope you enjoy your stay here. :)
  28. Jamie Smith
    Jamie Smith
    Jan 30, 2009
    Leeds, England
    Thanks. Nothing worse than a tense forum eh? Chilled out bunch ftw.
  29. Jack-Deth
    Jack-Deth
    Sep 25, 2003
    6,354
    Ireland
    +1,341
    Just don't mention the 360 pad and you'll be fine :rotfl:
  30. GizmoTheMogwai
    GizmoTheMogwai
    Nov 6, 2008
    612
    Norwich
    +45
    Haha, If your looking for a tense area, check out the 360 hardware area, as you can imagine, their consoles are breaking down every other day so it can pretty angry there :devil:
