PS2 with Ps1 games
T0rNaDo
i found 1 ps1 game used on the ps2 i couldnt use the ps2 component lead.
just couldnt get a picture.
i had to go back and use the yellow/red/white connection lead.
strange !
im wondering is it possible to save the game to the ps2 memory card.
if playing a ps1 game on the ps2 ?
T0rNaDo
and i guess the ps2 wont accept the ps1 memory card either.....
T0rNaDo
Mickus said:
Yes it will. (with a PS1 game) :thumbsup:
cool..... and i know someone that has a ps1 card too.
and i got a few ps1 games so i shall give it a try first..
T0rNaDo
well just tried it
a ps1 game with a ps1 memory card.
on a ps2 works fine and u can save too. :clap:
only prob is no picture when using the ps2 to component leads.
had to drop back to the standard av lead
thxs all for info....
mickus66
T0rNaDo said:
well just tried it
Whilst your connected via the composite cable, go into 'system config' and turn on 'component out' (Y Cb/Pb Cr/Pr). Reconnect your component cable and try again...
fallenangle
Very few PS2 games support prog scan, with PAL games you're lucky if you're even given a 60Hz option. But the fact is that using component leads will give you no better image quality with most PAL games than if you are using RGB SCART connections.
But as ^ says if you are using component you must reset the PS2 from it's main menu to the correct output.
T0rNaDo
thxs both for that info.
il give that a try nice time im on the ps2.
