PS2 WIRELESS CONTROLLER with RF
Discussion in 'Playstation Forums' started by Xstyle, Apr 6, 2005.
  1. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
    I want to be able to put my PS2 with my AV gear, behind a glass cabinet door. Therefore a wireless RF controller would be best.
    Would I need an RF extension to be outside of the cabinet, or will it work through the glass??
    I have come across this:
    Logic 3 Freebird Wireless RF Controller For PlayStation 2:
    http://specialreserve.co.uk/Logic_3_Freebird_7513_r.html
    What are your experiences?? Any ideas?
    Cheers,
    Xstyle
  2. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
    THREE STRONG CONTENDERS HERE... which one is the best?
    (i) Logitech vs (ii) Logic 3 Freebird vs (iii) 3G Airstyle
    :confused:
    LOGITECH
    http://www.logitech.co.uk/index.cfm...,CONTENTID=8157
    • 2nd generation Logitech® Cordless Action™ Controller
    • Smaller, lighter, more comfortable — in a familiar layout
    • 2.4 GHz radio frequency wireless technology with a lag-free range of 9 metres
    • Requires only 2 AA batteries to achieve 50+ hours of battery life with vibration on
    • Mini receiver plugs directly into console
    • Controller licensed by Sony Computer Entertainment Europe Limited for use exclusively with PlayStation®2 for PAL markets.
    LOGIC 3 Freebird
    http://specialreserve.co.uk/Logic_3...ird_7513_r.html
    • 15 metre (50 foot) range
    • Up to 100 hours of game play per set of batteries
    • Twin analogue control sticks with integral fir buttons
    • Vibration feedback effect
    • 8 way directional control
    • Four analogue shoulder buttons
    • Ergonomic design
    3G AIRSTYLE Wireless Soft Touch
    http://specialreserve.co.uk/3G_Airstyle_2442_r.html
    • E3 Best Hardware Award Winner
    • Very stylish design, soft touch finish and stylish blue LED on receiver
    • High performance Wireless Analog Controller
    • The latest unblockable RF wireless technology
    • Full Analogue/Digital Controller buttons and twin analog thumbsticks
    • Dual vibration motors
    • Play with up to 8 Wireless Airstyle controllers, automatic connection feature (over 65,000 security IDs)
    • Eco mode to preserve battery life
    • Sleep mode after 15 minutes without use and switch off after 1 hour without use
    • Up to 7 metres operational range
  3. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
    Logitech seems to be OFFICIALLY LICENSED BY SONY; and the reviews below say its 100% pukka!
    http://gameworldnetwork.pricegrabber.com/rating_getprodrev.php/masterid=2991931/id_type=masterid
    This could be the ideal choice peeps ... but then why did it not win awards at the E3 Awards (like the 3G Airstyle
    This is a major benefit of the Airstyle remote though!!
    The Logitech Cordless Action Controller ...which I was just about to buy... only works with its own RF receiver, which you have to have one per controller.
    It works on Radio A & B frequencies... so if you had a 3rd or more controllers they will get confused in the other frequencies. So a multitap is out of the equation.
    However according to Airstyle you can play 8 controllers with the one receiver... (max you'd prob need is 4 anyway)
    DILEMNA...
  4. Aladin
    Aladin
    Mar 9, 2005
    30
    9
    Opinions are like arseholes.....everyones got one!
    The best ones are of course the Logitech.
    Where will you get the rest of your kit from?
  5. Aladin
    Aladin
    Mar 9, 2005
    30
    9
    The Logitech comes with its own transmitter/reciever which plugs into the controller port?
