PS2 video drop out, help
Discussion in 'Playstation Forums' started by alistair, Oct 5, 2003.
  1. alistair
    alistair
    Bought an s-video and L & R audio cable for PS2. It outputs through my Denon 3803 to my Siim 300+.
    I am expereincing an intermittent loss of video although the audio is still there. CM04 is hard enough without doing it blind folded:p .
    Anybody got any ideas as to why this is happening? I have tried a different cable and still get the same result. Older games do it too so it's not a new game thing either. Plugging directly into the Sim 300+ gives no result so I suspect it's having trouble coping with the signal. Old fashioned cables gave me no issues.
    Help appreciated, thanks.
  2. stigdu
    stigdu
    Mar 23, 2003
    1,938
    Sutton
    +311
    Have the same thing happening to me with a component lead....
    Just a loose connection, I think. If I push the PS2 unit back into the stand, then the picture goes off, but if I pull the PS2 out, and give the cable some slack, then the picture is fine.
    HTH.
