PS2 via JS Converter
Discussion in 'Plasma TVs Forum' started by techcs, Mar 20, 2005.
  1. techcs
    techcs
    Mar 17, 2005
    11
    Just one more question...... How do I get PS2 to go through the JS - Vga converter. I have set the playstation to RGB and I am using a scart converter with a composite input from the normal playstation lead. I presume its not working because the JS box is expecting a "Fully connected Scart LEad" is that RGB, Horizontal and vertical sync all separated?
    Anyway was wondering what I need to buy for the PS2 to get it through the converter??
    Col
  2. techcs
    techcs
    Mar 17, 2005
    11
  3. techcs
    techcs
    Mar 17, 2005
    11
    Ah well.... no response, suppose that means majority of people simply use a componant input for PS2..
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    it sounds like the ps2 lead you are using is not rgb...that ebay one looks the job but I guess it needs you to use optical cable from ps2 to amp for sound?
  5. techcs
    techcs
    Mar 17, 2005
    11
    Thanks MEP.... will try.....
    Col
