PS2-VCR-SKY-Syncblaster VGA - will it work?
Discussion in 'Plasma TVs' started by ginga_dj, Jan 21, 2003.
  1. ginga_dj
    ginga_dj
    Jan 12, 2003
    48
    I wonder if anyone knows the answer to this.....
    I have ordered a syncblaster cable, Scart to VGA.
    I want to connect the Sky Digibox to the Tosh Plasma using this.
    However, I currently have the PS2 connected via Scart to the VCR which is connected to the Digibox via scart. This worked on my old TV Scart.
    Will the PS2 and the VCR be able to pass through the Digibox and work via the VGA connection?
    I can always use the S-video input on the Plasma for the PS2, my main concern is using the VCR. If I can play through the digibox I will be very happy.........
    ps. The Component inputs are being used by the DVD and I am not going to unplug that......
    any ideas?
  2. jont
    jont
    Apr 8, 2002
    3,917
    near Aylesbury
    +411
    Wouldn't have thought that you will get RGB pass thru from the Ps2>vcr>sky ...
    Why not connect vcr>plasma on the composite ... as that is all you'l get from a vcr unless its an s-vhs one and then you could use s-video ...
    go ps2>sky>syncblaster and activate RGB on both for the best picture quality ... that's how I had mine ...
    Jon
