PS2 USB Cable Extension?
Discussion in 'Playstation Forums' started by alistair, Nov 27, 2003.
  1. alistair
    alistair
    I want to buy Karoake Revolution for my daughter for Christmas. It uses a headset into the USB on the PS. My problem is my PS2 is hooked up to the projector and not in the same room. I can pass acable through the wall but suspect it won't be long enough to work. Question is then......does anyone know of a supplier of an extension cable of some kind? This is not available in the UK yet so I'm getting it brought back from US so I need a quick answer. Thanks in advance for your help.
  2. Messiah
    Messiah
    Apr 22, 2002
    7,543
    +338
    If it's a USB connection then a standard USB extension cable from the likes of PC World or similar will be just fine. I used to use on for the gun on shooting games.
  3. alistair
    alistair
    Thanks I'll try and check it out. Never used a game with that connection before so I'm pleasantly surprised to think it might not be a specialist cable requirment. If you only knew where my PS2 was buried you'd understand why I never venture round the back:)
  4. Messiah
    Messiah
    Apr 22, 2002
    7,543
    +338
    It must use a standard USB cable as the USB ports on the front of the PS2 are standard.
  5. alistair
    alistair
    even better, thanks for responding so quick, I'll start rehearsing my routines tomorrow
