PS2 to Yammy A2
Discussion in 'AV Receivers & Amplifiers' started by Taz, Jan 7, 2002.
  1. Taz
    Taz
    Hi all,
    I was just looking at the back of my A2 (as you do!) and noticed that my DVD RCA inputs are empty as is the DVD optical input.
    (my DVD is using the CD coaxial input... no optical out)
    would there be any problems in connecting my PS2 both RCA and optical to the DVD inputs :confused:
    Cheers.
    Taz.:cool:
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Nope - should work a treat.
    Make sure you enable digital out on the PS2 first though as I forgot and was going round crazy trying to figure out why my amp wasn't getting an audio signal from the PS2. Silly me :D
