PS2 to Sanyo Z1 problems..
Discussion in 'Projectors, Screens & Video Processors' started by adieacc, Feb 10, 2003.
  1. adieacc
    adieacc
    Feb 2, 2002
    128
    16
    South Wales
    I've just recently taken delivery of a Sanyo Z1, and am currently sending signals to it via S-vid (RGB from Cable box & DVD through RGB to S-Vid convertor) and everything seems to be working fine.
    But last night had some friends around with a PS2, which i tried to connect as above, through the RGB>Svid convertor. But the only picture i could get was a very, very faint picture in very dark red shades (totally un-watchable). Has any one got any ideas why??
    Or am i just missing something really obvious, as the stick i'm receiving about my new toy is unbearable.....
    Cheers in advance
    Adieacc
  2. talizker
    talizker
    Aug 21, 2002
    1,100
    +49
    Not much help I know but my PS2 is connected to the Z1 directly with a Sony S-Video cable and all is fine;)
  3. adieacc
    adieacc
    Feb 2, 2002
    128
    16
    South Wales
    Talizker
    Are all PS2 not identical then, as the one last night only appeared to have one scart output (outputing component or RGB) no other options in the set-up menus...
  4. talizker
    talizker
    Aug 21, 2002
    1,100
    +49
    You can't choose S-Video in the setup [ie you can't output S-Video signal through SCART] but the PS2 can output S-Video when using a S-Video cable. The Sony one is only £15 [I think!] from Game etc...
  5. stevelup
    stevelup
    Aug 13, 2002
    6,532
    Swindon
    +1,096
    I strongly recommend you use RGB with the projector and not S-Video. The results with RGB are much better.
    All you need is a SCART->RGB+Composite cable, and a normal VGA->5 x BNC cable. Join them together R->R G->G B->B and Composite->Hsync. Total cost should be under £50.
    No interface box is needed and the picture is incredible.
    Steve
