PS2 to monitor cable.
Discussion in 'Playstation Forums' started by Baggy69, Jul 12, 2004.
  1. Baggy69
    Baggy69
    Mar 15, 2002
    189
    Birmingham, UK
    +3
    Hi all, please can you help me, my monitor has 2 inputs, D-sub and 5 connectors showing red, green, blue, hd, vd. i just got a PS2 comp lead http://shop.uk.playstation.com/sony...=PlayStation+2+Accessories&product_id=9102700 and connected the red green blue with my monitor but i get no picture, ive been through all the settings on the ps2 just in case its something on there but it still doesn't work. Should this work or do i need a different lead? Please can someone help?
    Thanks Ian.
  2. Kalab
    Kalab
    Jun 16, 2004
    7
    Some computer monitors have 5 connectors, the standard RGB plus horizontal sync and Vertical sync. If you have on of these monitors you will not get any picture as the monitor is not seeing any sync signals.
  3. Baggy69
    Baggy69
    Mar 15, 2002
    189
    Birmingham, UK
    +3
    So is there a cable i can buy that will work ?
  4. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    The Wheldon Road end!
    +8,369
    There's no true VGA connection between a PS2 and a VGA monitor that I am aware of. The best you can get is one of those crappy VGA boxes that accept the video and audio jacks and turn the info into a picture that can be viewed on a monitor.
    I wouldn't bother though, I got one and the picture isn't up to much to be fair. Stick to RGB or Component (if your TV accepts) as these provide the best image.
