PS2 to Component cable problem !
Discussion in 'Playstation Forums' started by Markie Boy, Jan 13, 2003.
  1. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    Perth, Western Australia (Originally Ireland)
    +226
    Hi Guys,
    Recently bought a PS2 - Component Video cable on Ebay Australia. However when hooked up to my Panny AE100 PJ I get no picture. Is it possible this cable is made for the NTSC market? If so can it (cable) be modified to play PAL? Also, if I mod my PS2 to play NTSC games, does this enable NTSC out of the machine, thus solving my problem?
    Thanking you guys in advance!
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,506
    2
    71
    High Wycombe, Bucks, UK
    +59
    Is the PS2 set to output component Y-Cb-Cr rather than RGB?
  3. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    +226
    Good question!
    Last time I plugged in the PS2 (bout 6 months ago) was when I was still living in Ireland. Was using a SCART cable then, which I have since misplaced/left behind. Is there anyway of changing the setting without resorting to purchasing an RF mod just for this once off adjustment?
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,506
    2
    71
    +59
    Have you not got the basic composite video cable that came with it? That'll still work.
  5. museumsteve
    museumsteve
    Jan 28, 2001
    7,850
    4
    Nth Hampshire
    +1,057
    I'll boot my PS2 up later and do 'the count'. I'll be able to tell you the control presses to change to component without a cable plugged in.:) if you want..
  6. museumsteve
    museumsteve
    Jan 28, 2001
    7,850
    4
    Nth Hampshire
    +1,057
    Just done it.
    turn ps2 on with no game in (make sure turned on from scratch with no game in).
    Wait about 15 secs for start-up sequence to go.
    Press down on d-pad, then X
    Wait a couple of seconds, then press up twice on d-pad, then press X
    Press left once on d-pad, then press X
    then restart machine and should be done.:)
  7. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    +226
  8. museumsteve
    museumsteve
    Jan 28, 2001
    7,850
    4
    Nth Hampshire
    +1,057
    Pleased to help, that's what the forum's for mate.:)
  9. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    +226
    Does any of the mod chips for PS2 actually allow NTSC progressive scan when playing US or Jap games?
  10. olaiho
    olaiho
    In order to get progressive scan from a PS2 game, the game must have built-in support for progressive scan. There are a few titles that support progressive scan, such as:
    - Burnout 2 (USA)
    - Tekken 4 (USA and PAL)
    - The Getaway (USA, PAL)
    - Socom: US Navy Seals (USA)
    - Robotech Battlecry (USA)
    - NBA2K3, NFL2K3 (USA)
    There is also a disc available, which enables you to play PS2 games via a VGA adapter. I do not know the specifics, but from what I understand the disc contains codes to enable VGA only in certain games, not all. And I don't know whether the disc works with a PAL PS2.
    Best Regards,
    Olaiho
  11. olaiho
    olaiho
    Regarding the PS2 VGA disc + adapter .. It is manufactured by Blaze, and apparently it is a piece of crap =(
    Read here
    Regards,
    Olaiho
