PS2 to amp
Discussion in 'Playstation Forums' started by geeWcee, Nov 27, 2004.
  1. geeWcee
    geeWcee
    Oct 27, 2003
    1,412
    West Yorkshire
    +26
    Just got hold of a cheap PS2. I have an xbox already and connect it to my amp via toslink cable. I got a digital out cable for the PS2 but I dont seem to get any sound during games.....
    I presume no PS2 games use the optical out connection and I will have to connect to my amp using phono plugs?? Or have I picked up a faulty PS2?
  2. bobbetts
    bobbetts
    Dec 13, 2002
    154
    Norfolk
    Have you checked the setting in the PS2 menu, If I recall you need to enable it ?
  3. geeWcee
    geeWcee
    Oct 27, 2003
    1,412
    West Yorkshire
    +26
    yer digital optical out is set to ON - but am I right in thinking this is only applicable when watching DVDs using the PS2 unit?
    Bit dissapointed if none of the games are 5.1.....
  4. bobbetts
    bobbetts
    Dec 13, 2002
    154
    Norfolk
    I have mine hooked up with optical and get sound from the games although I understand the PS2 games are not fully 5.1. Have you tried your xbox cable?
  5. geeWcee
    geeWcee
    Oct 27, 2003
    1,412
    West Yorkshire
    +26
    Yer still no joy.....
    How is everyone else connecting their PS2 to their amp?
  6. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,417
    2
    In a secret location with Jennifer Lawrence
    +9,112
    Mine is connected via optical cable and it works fine.
  7. geeWcee
    geeWcee
    Oct 27, 2003
    1,412
    West Yorkshire
    +26
    Cheers Greg thats all I needed just one confirmation ;-)
    I must have a dodgy unit then.
  8. Dean
    Dean
    Jun 20, 2003
    2,861
    London
    +258
    There should be a red laser light from the port if the optical is set to on and working, quite easy to see in the dark.
  9. Pooon
    Pooon
    Dec 26, 2002
    7,295
    Canterbury, Kent
    +916
    Just to back up greg, my PS2 is connected to my amp via optical, works with all games as well so it's not only selected titles.
  10. geeWcee
    geeWcee
    Oct 27, 2003
    1,412
    West Yorkshire
    +26
    Cheers for the responses lads......
    Red laser present but no sound output. I'll get it exchanged if i can.
