PS2: The Component looks worse than the RGB?!?
Discussion in 'Playstation Forums' started by greenlocus, Jun 24, 2005.
  1. greenlocus
    greenlocus
    Hmmm. Was all excited: just got the Samsung 30" slim fit HDTV and hooked up my PS2 via the composite in order to program it to send component, then hooked up the component cables (sony PS2 brand) and the picture quality is way worse (pixelated / jagged).
    If you have HDTV, is composite the way to go. I always heard that Component was superior... Any suggestions would be appreciated.
    :suicide:
  2. SilverDragon
    SilverDragon
    Hmm, I have never heard of anything like this before. Was something unplugged or loose? I have had the same problem with my HDTV and DVD problems and some cables got a little loose.
  3. greenlocus
    greenlocus
    Nada_ I checked all the cables to make sure they were good and tight. One thing is that the TV is labeled as HDTV 1080i and I don't think the PS2 is made for that type of resolution... But really, I don't know (at all) what I am talking about when it comes to HDTV resolution, etc.
  4. nick501
    nick501
    May 6, 2005
    7,203
    Walsall, West Midlands
    +782
    same thing happend when i tried my xbox on lcd. I think these screens show bad graphics up somehow which crt's 'mask'?????
    I find some games are fine where as others look pants.
    roll on next-gen!!!
  5. PinkPig
    PinkPig
    Feb 14, 2005
    98
    It sounds to me like the composite signal is introducing general noise and inperfection into the picture, masking the low resolution and jaggies in the original console image - giving you a picture very much like you expect a console gaming picture to look. The component signal will, however, give you a much better representation of the output from the console, showing the imperfection and making it look worse.
    Hopefully, once the XBOX 360 and PS3 are here we'll have a much higher quality signal and component connections will start to look great!
  6. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,636
    167
    The Wheldon Road end!
    +7,839
    I have my PS2 hooked up to my PJ via component and the picture is great - much better than RGB or Composite.
  7. leeboy2k3
    leeboy2k3
    Jan 20, 2004
    237
    walsall
    +6
    No no no your all missing the point! the ps2 looks ugly through component not because of analog signal noise! but because the few ps2 games that support progressive scan will reveal what most people have known all along about the ps2.
    That it has has ugly texture mapping i.e. 4mb vid ram is not enough, no pixel shading.. poor anti aliasing on most games, topped off with poor colour bit presicion.. put simplt the ps2 is one ugly graphical mother fudder!
  8. Sarah Nya
    Sarah Nya
    I guess you could always try a good quality DVD and see what the PQ looks like?
  9. Dean
    Dean
    Jun 20, 2003
    2,690
    London
    +188
    I've always been more than happy with RGB with my PS2, especially through the IXOS range of cables.
  10. neoglow
    neoglow
    Nov 3, 2004
    92
    Hampshire, South UK
    What games are you playing greenlocus? Because some games support Progressive Scanning (480p, 720p or even 1080i) on the PS2, check here http://hdgames.net/ If the game can support it then you will get a much better picture through Component. The PS2 is by far the worst for graphics compared to the Xbox and Gamecube - most of which games for these consoles support progressive scanning as standard. I was stumpted recently with Burnout 3 Takedown which I finally discovered how to enable progressive scanning (see website above) Also if you have Gran Turismo 4, you can enable 720p or 1080i !!!!!
    Hope this helps, Mark.
  11. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,636
    167
    +7,839
    Just 480p & 1080i on GT4 - no 720p unfortunately.
