PS2 Sweetspot Dscaler Problem
Discussion in 'Desktop & Laptop Computers Forum' started by darktherapy, Sep 24, 2005.
  1. darktherapy
    darktherapy
    I currently have Sky going into my Sweetspot card and display it using DScaler with excellent results. However, I am trying to connect my PS2 into the back of the Sky box so that I can route it through to the sweetspot card when Sky is switched off. This setup works fine when using a RGB-VGA converter direct to the plasma, but when I route it through sweetspot I get a very small picture with very low brighness.... am I doing something wrong? I would prefer to use my PS2 RGB cable since the PQ is supposed to be better. Would I be better off using the second SVideo port on the Sweetspot?
    Thanks in advance for your help.
    Darren
  2. darktherapy
    darktherapy
    I'm still having problems with this. I purchased a PA2 - SVideo cable, but now the DScaler picture is black and white!
    Has anyone had this problem??
  3. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    36,172
    9
    13
    CyberSpace
    +10,694
    I have to state that I don't have the setup, but are actively looking into it....Could it be that Sky doesn't have RGB through ports? My Sky system doesn't have it? Actually it must have as you can get a picture...Hhmmm how do you do that as my Sky only has got two scart outputs, one RGB and one composite....
  4. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi DT
    I have posted a reply to the pixelmagic forums..let me know how you get on with this..
  5. darktherapy
    darktherapy
    For some reason it seems to be working now. I would love to tell you how I fixed the problem, but I really don't know.... maybe it was a loose connection
    Thanks for your help
