PS2 SVideo output
Discussion in 'Playstation Forums' started by Dunky, Jan 16, 2002.
  1. Dunky
    Dunky
    Nov 15, 2001
    60
    Surrey
    Can anyone tell me what lead I need to connect my PS2 to my TV's scart socket in order to receive SVideo signal? I don't want to use the SVideo socket on my TV 'cos, like most, it's under a flap on the front and looks untidy in use. My second scart on the TV is capable of receiving SVideo signals.
    Cheers.
    Dunky
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
  3. graham.myers
    graham.myers
    I've got a gold scart connector with three phono and one S-video connector. I used them for my LD (only had a Scart for output) now its connected to the amp via S-video. I also use it for my PS-1 and PS-2 in various tellies around the house.
    You just plug your PS-2 cable into that be it composite or S-video. Works fine. the scart is switchable for in or out. Obviuosly for a Ps-2 this would be in :)
    I've a couple left (I bought loads 'cos they were cheap :) If you want one email me. (A couple of quid +P&P)
