PS2 SS / DMS / Messiah / RGB - Help
Discussion in 'Playstation Forums' started by Nunoc, Nov 29, 2003.
  1. Nunoc
    Nunoc
    Mar 14, 2003
    25
    Cape Town
    Hi Everyone,
    I've looking at buying the Limited PS2 SS in the next few weeks.
    However I'm just wondering about a few things which I hope you guys help.
    I'll be looking to connect up the PS2 via RBG scart to my Widescreen TV.
    I hear the IXOS is a good cable but I checked on their webiste and
    it does not mention if it is fully wired which I also hear is important.
    Firstly, does anyone know if it is fully wired ???
    Secondly, is it worth the extra cash compare to the 5 GBP cable over at the whitedog site ??
    I'm also going to use the QED optical for sound, connected to my home theater amp.
    Lastly and most importantly. What are the pros and cons and/or differences between the Messiah 2 Pro and the DMS 3 chips. Can one have them both fitted ???
    Any help, suggestions and comments are most welcome.
  2. phenom2003
    phenom2003
    The chips will not really make a difference if just playing back-ups and imports.
    You will not need a fully wired scart if you are only going to use RGB. The extra money for the IXOS cable is definately worth it, you will get a much cleaner image than cheapy £5 scarts (which even though they say they are RGB they aren't always)
    Rich
  3. wod
    wod
    Sep 7, 2003
    196
    +3
    the only difference between them is that the dms3 has over messiah 2 is
    option to flash the chip firmware to newer version
    dvd multiregion
    macrovision off
    able to run things like the divx player off the memory card
    http://www.dms3.com/specs.htm
