PS2 Speedster 3 Steering Wheel
Discussion in 'Playstation Forums' started by sisko, Aug 21, 2004.
  1. sisko
    sisko
    Nov 8, 2002
    494
    Comber, N Ireland
    +26
    I am thinking of buying the PS2 Speedster 3 Steering Wheel and want to know how long the leads are.
    Are they the same length as the leads of a standard controller?
    Has anybody got one of these or can anyone recommend another wheel.
    Hope someone can help.
  2. Tetlee
    Tetlee
    Jan 21, 2004
    20,271
    Taunton
    +4,775
    I have the Logitech dual force feedback steering wheel, the wheel itself is fantastic, and perfectly responsive. I bought mine as a package with GT3 ages ago but I think you can buy it fairly cheap now so I'd recommend that one.
    As for the lead length, it is about the same as the standard controler as I would suspect they all will be. But all I did was nip out and bought a USB extention cable, then you can extend the cable as long as you want :thumbsup: .
  3. sisko
    sisko
    Nov 8, 2002
    494
    Comber, N Ireland
    +26
    Thanks for the help.
    I will check out prices on both.
