PS2 setup
Discussion in 'Playstation Forums' started by Lex, Mar 29, 2002.
  1. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Hi all,
    Was just fiddling around with my PS2 when I noticed in the setup that you can change the 'Texture Mapping' and 'Disc Speed' from 'Standard' to 'Smooth' or 'Fast' respectively.
    Why is this feature there? Does this actually do anything? Should I be changing it around for different games/DVDs?
    Thanks in advance,
    Lex.
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    As I understand it, it's simply to optimise performance for playing PS1 games.
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Cheers.
    So do I set the texture mapping to smooth and the disc speed to fast when playing PS1 games then?
    Lex.
  4. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    No idea. That's just how I understand it. I could be wrong.
    I'm sure it says something about it in the manual.
  5. museumsteve
    museumsteve
    Jan 28, 2001
    7,851
    4
    Nth Hampshire
    +1,058
    'texturing' setting smooths out some of the jaggies on some of the games. It makes no difference on 2D games at all and there are not many games that really benefit. Gran Turismo 2 is one that does spring to mind.
    'disc speed' increase the disc speed of PSone games and should increase loading times. On some games I've known it to half the load times, but there are drawbacks as some games that have music or sound streaming from the disc struggle (a lot).
    It's really a matter of trial and error, but worth messing around with.:)
  6. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Cheers museumsteve,
    I'll have a play around with it all!
  7. Doubledoom
    Doubledoom
    Whatever you change it to, it always goes back the default when you reset/turn off.
