PS2 S-Video 60Hz?
Discussion in 'Playstation Forums' started by Intera, Feb 24, 2005.
  1. Intera
    Intera
    I have a Sony S-Video cable for my PS2, I was just wondering does this cable automatically display 60Hz in games that support 60Hz? Or is there something I have to do - i have noticed 60Hz options in some games but not others (even new ones), does this mean there is no 60Hz if there's no option?
    Also, at the moment I have the official Sony S-Video cable which was like £19.99, but today in GAME i saw an own brand "fully-wired" RGB cable for £14.99, is this better than S-Video? I only ask since I run my cube through an official Nintendo RGB and the quality is probably the best out of any of my consoles.
    Thanks.
  2. Loewe
    Loewe
    RGB is generally better than S, but you can't watch DVD with RGB/PS2 and most cheap RGB-cables are not or badly shielded. So Your S-video cable is maybe the best choice. Much better than composite (the one yellow cable) and even with a good RGB you would probably not notice a difference from S-video. Depending on your TV.
  3. Loewe
    Loewe
    S supports 60 hz.
  4. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    31,147
    Bristol
    +5,939
    To get round the green screen effect when watching DVDs with a RGB Scart Cable just get a copy of DVD Region X and it will remove the problem.
