PS2 Region X - DTS output?
Discussion in 'Playstation Forums' started by ag005613, Jun 21, 2002.
  1. ag005613
    ag005613
    Jun 21, 2002
    52
    I have just purchased the DVD Advantage pack including the PS2 Region X utility. This seems to be working fine except that I do not appear to be getting DTS output from my Region 1 DVDs. (I only have one region 1 DVD so far - the U2 Elevation Tour DVD). MY PS2 is connected via the digital optical cable to my home cinema. Usually when the Sony Cinema unit (HTK - 215) recognises DTS it displays it on the display but it seems to think that the U2 DVD is non-DTS and is just outputting it in Prologic format. I have not had this problem with any region 2 DVDs and I was wondering if perhaps the region 1 DVDs use a different form of encoding for the DTS signals? (I really don't have a clue here). Either that or the Region X utility maybe does not work with DTS/5.1?
    Any ideas?
    Thanks.
    Stu
  2. NeoBlade
    NeoBlade
    Make sure you've enabled the DTS soundtrack on the DVD... Most only output in Dolby digital 5.1 until you select DTS....
  3. damtom1
    damtom1
    Turn on PS2 without a disc and axcess the menu,change the settings to allow dts.I seem to remember somthing relating to "bitstream".
  4. NeoBlade
    NeoBlade
    There isn't a DTS option on the PS2's operating system... However you would have to select "Optical Out" for audio, as you would for the ratio (16:9 or 4:3) and connection (RGB or component).
  5. ag005613
    ag005613
    Jun 21, 2002
    52
    Thanks for replies - I actually found this myself - it helps if you try the audio options on the CD! Whoops.
    Stu
  6. BoilingPoint
    BoilingPoint
    He,he .. Is'nt it always the way ;)
