PS2 Problems
Discussion in 'Playstation Forums' started by RockStrongo, May 25, 2005.
  1. RockStrongo
    RockStrongo
    Jan 11, 2005
    874
    28
    Newcastle
    +53
    Hello,
    Was wondering if you may be able to help me?
    I have a problem with a PS2. After watching a DVD recordable copy of Jerry Maguire (I know, I know) the PS2 now won't play games properly. When I insert a disc, it loads and the flicks through all the menus as if a button was stuck on the controller even if I take the controller out. The pointer seems to move on it's own as well. After it's been through all the menus it won't let you select anything at all.
    Any ideas?
  2. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,786
    167
    The Wheldon Road end!
    +7,954
    Nope, strange on that. Have you tried fully turning the system on and off using the switch at the back.
    Sometimes if I play an import game and then try a UK game without a full turn off with the rear switch, then it comes up asking me to insert a proper Playstation 2 disc. This will be something to do with the mod chip still being in the wrong region I guess and the power must still get to it unless the unit is fully powered down.
    Different problem I know but it's worth trying.
  3. RockStrongo
    RockStrongo
    Jan 11, 2005
    874
    28
    Newcastle
    +53
    No I haven't tried that, but I will now.
    Thanks again!
  4. Chox1988
    Chox1988
    Mar 30, 2005
    16,821
    basingstoke
    +9,278
    I get that all the time, I've found I have to blow into the bit where the controller slots into on the front of the PS2.
