ps2 picture problems
Discussion in 'Playstation Forums' started by ssimpson31, Mar 14, 2005.
  1. ssimpson31
    ssimpson31
    hi guys
    i have a new small ps2 i am using a ixos componant cable
    via my pionner ax5-is this is conected to my panasonic dw7 42"
    my problems is around 50 % off the time i have no red so the picture goes
    all funny the red looks green and everything is washed out
    i bought the ps2 from tescos around 3 weeks ago and today i just got a
    refund and bought another ps2 this time from argos
    but i have the same problem my amp and dvds and freeview are all fine
    all use componant exept dvd which uses hdmi
    i have gt3 and fifa 2005 and gt4 all suffer with the same problem
    any help would be great as i love gt4 and it looks terrable without the red
    its just a joy every now and then when the red works
  2. benmiles
    benmiles
    Feb 9, 2005
    47
    Maybe the red component cable on your lead is ****ed :)
  3. ssimpson31
    ssimpson31
    but it works 50 % off the time when i start playing its fine then 10 mins in the red goes then around 20 mins later its back and its alway when i finish the course and go back to the menu screen
    and the cable is never touched or fiddled with
    but you could be right with the cable but seems odd how it works sometimes
    thanks
  4. benmiles
    benmiles
    Feb 9, 2005
    47
    If it is a dodgy contact, it may make and loose contact with temperature variations.
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,123
    Galactica C.I.C.
    +350
    sounds like a dodgy lead. try moving the conetion about and see if it makes any difference to the picture,if it does then it is the lead/contact on the lead/ if not then it could be the playstaion 2 itself. in which case take it back if it is only a few weeks old.
  6. ssimpson31
    ssimpson31
    thanks guys its now sorted it was the conection like you said
    the lead was fine just moved the plugs around and now bingo its right
    thanks again
  7. mark rosser
    mark rosser
    Aug 24, 2000
    460
    solihull, west midlands
    +69
    could you confirm how you fixed the colour, as it sounds exactly like the fault i have!
    cheers :)
  8. ssimpson31
    ssimpson31
    i just pulled the leads out off the back off my amp give them a clean and put them back in
    works fine now
