PS2 or XBox on LCD Monitor
Discussion in 'Xbox Forums' started by Greg Hook, Nov 28, 2004.
  1. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,570
    In a secret location with Jennifer Lawrence
    +7,371
    Is it possible to play my PS2 or Xbox on a 17" LCD Monitor, which I use for my PC. Not PC and console at the same time, I would disconnect the monitor from the PC first.
    My XBox and PS2 work off the main TV so my gaming time is severely restricted at the moment, it would be great to get them working off my PC monitor which is in another room.
    If they do work, what is the picture quality like compared to RGB through the TV?
    Greg
  2. Pooon
    Pooon
    Dec 26, 2002
    7,127
    Canterbury, Kent
    +731
    It won't work unless the LCD monitor in question has some form of video in. Neither the normal monitor connection, d-sub, or if your a lucky person DV-I, are compatible with xbox/ps2. The only way to use your computer monitor with your console will be to connect the console to the PC using either your graphics card or a separate VGA box.
    NB: if what i have just written is complete :censored: i'm sure someone will correct me.
  3. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    Liverpool: European Capital of Football 2005/2006
    +76
  4. Greg Hook
    Greg Hook
    Nov 25, 2001
    20,570
    +7,371
    Excellent, thanks for that BauerCTU.
  5. Johnnypanic
    Johnnypanic
    Aug 4, 2004
    201
    +16
    Why not buy a cheap pc tv card with composite input and connect xbox via this ?
    Johnnypanic
  6. Greg Hook
    Greg Hook
    Nov 25, 2001
    20,570
    +7,371
    Wouldn't that mean I would have to have my PC on everytime I wanted to play on the console?
  7. Johnnypanic
    Johnnypanic
    Aug 4, 2004
    201
    +16
    Sorry it would, didn't really think about that, as my pc is never turned off.
    Johnnypanic
  8. Greg Hook
    Greg Hook
    Nov 25, 2001
    20,570
    +7,371
    I am just after the easiest option and it looks like that adaptor is just what I am looking for.
    My PC is so noisy it would distract when playing games on a console if the PC was on!
