PS2 on Plasma
Discussion in 'Plasma TVs Forum' started by 911uk, Jun 13, 2002.
  1. 911uk
    911uk
    Does anyone know where I can get hold of a cabe to connect the PS2 to my Panasonic Plasma - component/RGB type would be best I guess..?
  2. jont
    jont
    Apr 8, 2002
    4,321
    near Aylesbury
    +572
    Lik-sang (do search on gaming forum for website) do a range of ps2 cables ... the one i'm looking to get does ps2 to RGB component on 3x phono ... about a tenner all in I think ... although the cable quality doesn't look up to much ....
    If you want to splash out the Monster do a range of PS2 cables - 3 levels ps2 to composite, ps2 to s-video and ps2 to rgb ... about 25, 40 and 55 quid I think ...
  3. zcaps57
    zcaps57
    try your local HMV. Component Video Cable is the way to go.
    I've seen couple of them at HMV in Oxford St, London.
    I'm playing PS2, GameCube and XBOX on 106" screen, but in my opinion, PS2 seriously looks bad in graphics/picture on big screen display. lack of anti-aliasing, progressive scan...etc :(
