PS2 on Plasma screen
Discussion in 'Playstation Forums' started by js1, Dec 30, 2004.
  1. js1
    js1
    Hi Can anyone tell me if there is a booster/enhancer connection I can buy to get a sharper picture using the normal ps2 lead connected to my DVD recorder/Plasma screen? The picture on a normal TV seems a lot better. I should add the plasma has no inbuilt tuner so I use the DVD recorder to tune the channels
    thanks
  2. rubadub
    rubadub
    I have seen component leads for the PS2 on ebay. Don't know how good they are. They also have VGA boxes for them.
    Both were cheap enough
  3. Dave777
    Dave777
    Oct 25, 2002
    489
    Gatwick
    +16
    Get a component lead from PS2 into plasma. Fantastic picture. Use the digital audio out on back of PS2 into amp (if you have that) for best sound. Don't forget the menu options on the PS2 to activate the component out.
    Dave
