Ps2 on LGPX11??
Discussion in 'LG TVs Forum' started by bigval, Feb 10, 2005.
  1. bigval
    bigval
    Dec 30, 2004
    996
    28
    +25
    Got it on second scart socket at the moment.
    Seems a little blurred.
    Will component make it any better?
    Do I have to spend £20+ on one or will the £6 to £10 ones work just as well?
    thanks for anyhelp.
    Also wouldnt mind a suggestion of where to get one from.
  2. Kakihara
    Kakihara
    Jan 28, 2005
    13
    Component will give you the best image quality
    you should NOT use the 2nd scart socket on your LG anyway as it is only a composite scart, if I'm not mistaken only the first one is accepting RGB signals and if you don't already use a RGB scart for your PS2..big mistake lol (quality is a lot better already with a RGB scart)
    1-component
    2-RGB scart
    3-composite scart
    that'0s the best choice for PS2
    I'm saying this based on what I saw at a friend's house...
    I'm only getting my plasma friday and actually I bought it to play Gran Turismo4 on it.
    gran turismo 4 features a 480p and "fake" 1080i which will give you a kind of anti-aliasing actually, to use those resolutions you need a component cable so I bought one today :)..still waiting for the game tough...
    edit:
    the blur you speak of must be because you use the standard PS2 composite cables, composite is awfully blurry
