ps2 noisy backwards compatibility?
Discussion in 'Playstation Forums' started by Spazwunkle, Jan 29, 2004.
  1. Spazwunkle
    Spazwunkle
    heyhey all
    Original Silent Hill that I ordered off chilloutgames.co.uk arrived today.
    Popped it into my ps2 and it seems to make a hell of a noise when loading.
    The game seems to work fine (apart from when I died and it just continually made the loud loading sound), but just wondering if this a usual thing with ps1 games playing on ps2? or is there something wrong with the disc?
  2. Spazwunkle
    Spazwunkle
    hey again
    Does anyone have an answer to this? I need to know whether to send this back or not.
    Is it usual for ps1 games playing on ps2 to have such a noisy load? (everytime the disc spins)
  3. ThePunisherTXB
    ThePunisherTXB
    I can't help. All I can tell you is that I've played plenty of PS1 games on my PS2 and have had no such experiance.
    Try other PS1 games and see if there is still a problem. Maybe your PS2 can't run PS1 games properly.
  4. _Sin
    _Sin
    Oct 25, 2003
    104
    +7
    Do you have many CD based PS2 games, as opposed to DVD based ones? (PS2 CDs are blue, DVDs are silver with subtle PS logos).
    Just curious if you could try running a PS2 CD based game and comparing the noise it makes. Recent games are almost entirely DVD based, so it may be that you haven't played any...
    CDs tend to be a bit louder, and can also be one of the first things to start going wrong if the drive is a bit out of whack. Without more to compare though, it's difficult to say.
  5. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    I get a lot of noise using Monsters inc PS1 on my PS2. But no problem with PS2 games so Im not worried
