PS2 Noise
Discussion in 'Playstation Forums' started by jenic, Feb 19, 2005.
  1. jenic
    jenic
    Dec 10, 2004
    2,917
    83
    +182
    I switched my PS2 on this morning and when it was reading the disk it was making really loud sounds. It still worked ok but i could here it over my tv. I've had it for 3.5 years now. Is this a sign of it breaking?
  2. Pooon
    Pooon
    Dec 26, 2002
    7,567
    Canterbury, Kent
    +1,219
    If it's only done it the once the maybe not, but if it continues then it could be the lazer getting to the end of it's life, in which case it will be time to pop out and buy yourself an xbox:devil: or another ps2.
  3. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    Or the disc might not have been in correctly so it wasn't spinning straight...I've had this happen in CD-ROM drives, very disturbing!
    iamtheone - sorry for nitpicking, laser's spelt with an "s"...again sorry, that particular americanism sets my teeth on edge :)
  4. jenic
    jenic
    Dec 10, 2004
    2,917
    83
    +182
    Now its happening all the time with different discs
  5. Pooon
    Pooon
    Dec 26, 2002
    7,567
    Canterbury, Kent
    +1,219
    Yeah that is correct, but it LOOKS :D better with a Z than a S
  6. StevieGfan
    StevieGfan
    If its a clicking sound its the laser guide arm (a piece of grooved plastic the runs on a worm drive), Its quite an easy fix if your comfortable opening your ps2 up.Let me know if you need more info
  7. jenic
    jenic
    Dec 10, 2004
    2,917
    83
    +182
    Its more a really loud spinning sound, like the disc isnt in its tray even though it is
