PS2 No picture on Component
Discussion in 'Playstation Forums' started by Kippers, Dec 16, 2004.
  1. Kippers
    Kippers
    Hi gang,
    I've got a panny PWD6 and a Yamaha home cinema amp which I run all the cabling through. My DVD and everything else works fine via component, but my PS2 shows nothing. Just a big 46" black nothingness. I've set the PS2 to component out in the menu and use an Ixos cable, but there is nothing at all.
    Please help, I'm desperate to get my PS2 fired up via component.
    Thanks in advance.
    CHris.
    :confused:
  2. daveb975
    daveb975
    Oct 25, 2002
    3,989
    103
    London
    +275
    Are you going into a component board on the PWD6 or the VGA input?
  3. Kippers
    Kippers
    VGA input. Why will that make a diff?
  4. daveb975
    daveb975
    Oct 25, 2002
    3,989
    103
    London
    +275
    It shouldn't do, I was just going to see if I could replicated your set up on mine. I have my Xbox connected to the VGA input, and it works fine, and have tried my PS2 on the component board.
    I can't try my PS2 via VGA as I haven't got the right lead.
  5. McGraw
    McGraw
    Sep 29, 2004
    312
    +11
    There are two types of component, sounds like an incompatibility to me.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    YPbPr is analogue component aka YUV, YCrCb is digital component (try plugging the PS2 direct to plasma ) swapping DVD and PS2 inputs on amp..... etc could it be duff cable?
  7. Kippers
    Kippers
    I've tried swapping the cable to the DVD input and still no signal....Hmph... Could be a duff cable I suppose. I could try buying a cheepy one from Game or summit and see if that works??
  8. Kippers
    Kippers
    YAY IT WORKS!! Unfortunately not with my PS2 ... DOH!! I've tried using a friends new silver version and it works (although only through 1 of the inputs on the amp!). Must be some flaw or difference in the signal between the original version 3's and the newer ones I guess. Now I've gotta buy a new PS2, a well, could do with a new one anyway - mines been run into the ground (3 new lasers so far!!)
    :clap:
  9. Leicester Dave
    Leicester Dave
    ....BEFORE you go and buy a new one, have you switched your PS2 video output to Yuv instead of RGB on the "options" screen (boot without a disk) ?
    Given that you can't see the picture on the Plasma, you'll probably need to connect another TV to it to be able to switch it, though.....
    Dave
  10. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,392
    Cornwall
    +93
    i have a similar setup, pwd6, ixos component and older ps2. directly into a board all works fine.
    maybe worth (as someone else said) trying straight into the board, and then your friends ps2 going through the amp. You wouldn't want to shell out the cash on a new ps2 and find the amp doesn't like the signal.
  11. rob27
    rob27
    Nov 2, 2004
    161
    +9
    Hi, are we talking about UK PS2's ... as i am tempted to get one of the new PSTwo's if it can do component and better res progress scan ???
    My xbox is lovely. Just thinking about MGS3, GTA5 and GT4 :)
    Rob.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    we are talking UK not sure if you can push 100i out but the new silver ones are progscan and I am pretty sure the new ones can alll output component
