PS2 + long SVideo lead to amp?
Discussion in 'Playstation Forums' started by Mario Nicholas, May 20, 2002.
  1. Mario Nicholas
    Mario Nicholas
    Apr 2, 2002
    820
    Surrey
    +86
    I want to connect a PS2 to a Denon amp using the SVideo input connection.
    Where can I get this cable? extra long?
  2. G.M
    G.M
    Monster cable do a lead called the Gamelink 300 a 10ft long
    s-video with 2 phono leads.
    regards,
    G.M.
  3. Mario Nicholas
    Mario Nicholas
    Apr 2, 2002
    820
    Surrey
    +86
    Thanks - problem solved
  4. AMc
    AMc
    Nov 20, 2000
    7,145
    Near Norwich
    +3,833
    The controller extension route with short S-Video lead was best for me. The PS2 sits behind the TV and it means I don't have to disturb the optical cable to move it out onto the floor.
    Controller extensions cost about £4 for a 2 metre lead and can be daisy chained together. I got one from HMV and another from Game. If you're not bothered about colour then PS1 leads work too.
    Obviously there is no visual quality loss with using a long controller lead and I've never noticed any difference in playability.
