PS2 laser calibration
Discussion in 'Playstation Forums' started by Falp, Aug 12, 2004.
  1. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Can I do it like I can in a DVD player by it's service menu?
    How? :confused:
    Thanks! :thumbsup:
  2. panama
    panama
    Jun 3, 2004
    60
    don't know, but had to take mine in to a place in Leicester to have it done.
  3. snake II
    snake II
    May 19, 2002
    353
    luton
    +5
    what does it do to the laser? what is the laser calibration?
  4. cruncher75
    cruncher75
    Nov 1, 2003
    1,454
    southampton
    +119
    Calibrating the PS Laser
    Open up the PS2 unit, also remove the bottom casing and the metal shielding from the mainboard.
    Locate and remove the DVD drive's ribbon cable from the mainboard.
    It's easy, just click the connector's black strip away from the board and it slides out.
    Not only remove the cover and white disc from the DVD drive, but also unscrew the whole drive unit itself from the PS2 and take it out.
    Turn the PS2 upside down with its power connector and AV Multi Out facing you.
    Get a Neo Geo cartridge box (or something else about 1 inch thick). Use it to put on the DVD drive and connect the ribbon cable back to the mainboard.
    Get an item like your mousepad (or anything else NOT metallic or electrically conducting in any way with roughly the same dimensions as the mainboard). Put it on the PS2's mainboard and flip the DVD drive over on the mainboard with the ribbon cable still connected.
    If the downside of the laserunit itself is not visible, simply turning on the PS2 for a few seconds will make it slide to the center. Remember to shut the PS2 down again before progressing further!
    Now that you see the laserunit, located on the topright side of it are two small silver screw like components. These are adjustable resistors which you can use to adjust the properties of the lens.
    Note very precisely in which direction they are both facing before doing anything, so you can always restore the original situation.
    Using a small screwdriver, make adjustments to these resistors by CAREFULLY rotating them a bit each time until your backup copy runs flawlessly:
    Boot up the PS2 Utility CD
    Swap with a Backup CD
    If it will not run correctly or skips, power off and make adjustments
    repeat until either the PS2 works or until you can't deal with the frustration anymore, because this can take some time!
