PS2 Gamepad Extension Cable?????
Discussion in 'Playstation Forums' started by WBC, Dec 11, 2002.
  1. WBC
    WBC
    Guys,
    Anyone know what the longest extension cable you can get for a PS2 gamepad???
    I've seen cables about 8ft long but I need to stretch to about 20ft. Worse case scenario can I just daisy chain more than one??? :confused:
    I don't want to go out and buy a load if it doesn't work!!
    Stace
  2. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,844
    72
    birkenhead
    +82
    you can get RF controllers on import mate the cost a bit but might look better than a load of daisy chained wires lol.
  3. WBC
    WBC
    Cool.
    Are they any good though??? Do they work as well as the sony or is the general raving about the sony aload of bull???
    I always read the sony is the best pad out there, is it true??
    Have you got any recommendations?
    Stace
  4. RichB14
    RichB14
    Nov 8, 2002
    785
    Surrey
    +19
    Check out the new Logitech models look quite tasty
    logitech
  5. WBC
    WBC
    Has anyone played with the logitech cordless????
    Have seen different mixed reviews?
    Stace
