PS2 game pad extensions
Discussion in 'Playstation Forums' started by Gee, Oct 30, 2001.
  1. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    Does anyone know where I can get some PS2 game pad extension cables from that are around 5 - 10 metres long? I've seen some but they are only 2 metres.
    Matt:)
  2. Jenz
    Jenz
    Well you could always daisy chain them :D
  3. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    An alternative may be a remote transmitter device.
    I saw one for the PS2 in GAME a couple of weeks ago. You connect the receiver into the PS2 game port, and then plug a PS2 controller into the transmitter unit. You can then use the controller remotely.
    It cost about £30, but I don't know how good it is in practise.
    Nigel.
  4. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Up to 10 metres?!? Why do you need to sit so far away? Are you renting and plugging the machine into a screen at your local multiplex, or storing the console at a neighbours house?
    Blimey.
  5. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    I perhaps went a little overboard there...
  6. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    I want to run the cables behind a false wall so that I don't have cables all over my room. I was thinking of putting the cables under my seating so you can connect my pads directly.
  7. Taz
    Taz
    Gee, I did exactly that, but without the need for extension cables.. I just cut the ends off of a 2m extension (leaving around 10 cm of wire on the plug and socket) and soldered a length of decent multi core cable between them!... problem solved!
    Taz.:cool:
  8. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    Taz,
    Thanks for the reply! What type of multi core cable did you use (how many wires are needed) and where did you get if from?
    Thanks:D
  9. Taz
    Taz
    Gee,
    I'm sorry to tell you that I used to work for a juke box company and thats where the cable came from.. in this case it was 18 core,
    but i should think that any decent multi core cable will do the job as its only carrying 5 volts max. why not try Maplins etc for a length of cable? as for the number of cores req. i dont remember so snip it and see! ;)
    I ran my cable behind the PS, through the basement, and up under the front of the sofa so i could just 'plug and play'!
    best wishes
    Taz.:cool:
  10. Duncan Harvey
    Duncan Harvey
    hmmm...
    I bought a load of extension cables and daisy chained them - the result - problems!
    Whilst playing SSX the game kept going into pause mode, making it totally unplayable.
    When I got rid of all but one of the extenders - no problem.
    Am I doing anything really stupid, or it there a "rule" about daisy chaining extension cables?
