PS2 Fuse
Discussion in 'Playstation Forums' started by highlanders, Nov 9, 2003.
  1. highlanders
    highlanders
    Aug 24, 2000
    835
    Manchester, England
    +58
    Hi all
    My PS2 is dead used it last night switched off then switched on today nothing :( So before I send it for repair have a look at the fuse but how? (not under guarantee)
  2. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    You'll probably need to remove the case and get to the PSU board. Take a look at the mod chip instructions on www.psxservices.co.uk or www.kanection.co.uk
    They have guides on opening the cover. It's not too bad but be careful of the ribbon cable going to the power switch.
    Good luck.
  3. highlanders
    highlanders
    Aug 24, 2000
    835
    Manchester, England
    +58
    Thanks Massiah
    Changed the fuse and switched on lit up and started to smoke :( Had a look at the links you sent and I may need a new power supply.
