PS2, E55 recorder and 60 Hz
gstadt
All,
have done a thorough search but can't find the answer to my question. I have tried to change the output on Burnout3 and Prince of Persia to 60hz but keep on getting a blank screen. I have a PS2 looped through a Panasonic E55 recorder, using a PS2 Ixos RGB scart into the E55 which then upconverts to component. On a previous thread it was mentioned that the E55 only does NTSC at 60hz. I have no problems playing 50hz games though.
Anybody experience similar problems? :(
Many thanks in anticipation
avolee
if your panny is set to rgb, then the ps2 has to be rgb output into the panny,because its converted to composite thats why the screen goes blank, i have a similar thing on sky, when looped through my e65 panny as soon as i press tv button and the signal goes to composite, the screen goes blank, so either set your panny to composite output or ps2 to rgb
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
