PS2 DVD Parental Lock!
Discussion in 'Playstation Forums' started by Lex, May 4, 2002.
  1. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Hi all,
    Can someone help me turn off the bl**dy parental lock on my PS2!!!:mad: :mad:
    I can't find my manual so don't know how to do it!
    :mad: :mad: :mad:
  2. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    According to the manual (I haven't tried this):
    1. Select Custom Setup from the setup display
    2. Select Parental Control using direction buttons and press X.
    3. You can then select the relevant region and change the setting to off.
    4. If you can't remember the password, you can press SELECT and then enter the number 7444.
    Hope this helps.
    Andy
