PS2 Dodgy laser REPAIR?
Discussion in 'Playstation Forums' started by hornydragon, Dec 14, 2004.
  1. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    A friends PS2 is getting really fussy about reading blkue backed discs....... dodgy laser?
    A where can i get one?
    B How much to pay?
    C how easy to fit?
    Found one company offering a £65 replacement service but new ones are £95 and its 4 years old + new one is smaller quieter and get a controller......... so £30 is worth repair £65 + Shipping aint.......
  2. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    13,404
    oop north.
    +3,004
    have you tried turning the PS2 upside down? It used to work on the old PS1 if the laser got a bit too old...
  3. w3dal
    w3dal
    Aug 4, 2002
    5,031
    Chelmsford, Essex
    +584
    I have a similar issue. My PS2 is 4 years old and needs a new laser. I have found replacement ones on ebay for about 30 quid and they send you instructions on how to fit them.
    I dont know whether to just buy a new PS2 or have this one repaired. The only thing is my current PS2 has the Messiah mod so if i buy one of the new ones ill loose the modchip. Saying that i could get it moved over.
    Decisons Decions..
    Dal
  4. plaver
    plaver
    Oct 12, 2003
    2,408
    Bannockburn , Victoria, Australia
    +108
    :hiya: How do you know/identify that the laser is faulty, is there a test disk?????
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    well it not reading certain discs says to me laser at fault (play fine in other PS2 and one was brandnew blue readable surface)
  6. plaver
    plaver
    Oct 12, 2003
    2,408
    +108
    Did you get a replacement laser from ebay or ?
