Ps2- Dav Sc5 Av System
Discussion in 'Playstation Forums' started by DeepDiveDave, Jun 13, 2004.
  1. DeepDiveDave
    DeepDiveDave
    Hi, I wonder if anyone can help! I have recently aquired a sony DAV-SC5 Surround sound system! While setting it up the manual touched (But only Touched)on the point that I could direct my playstation sound through it with the use of a digital cable! I have bought the cable plugged in to both the appliances to no avail!! the sound system has different settings including Pro Logic II and one that says Game,I have tryed both with no result( I also turned the optical option on the playstation) Can anyone suggest anything? Dave.
  2. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    are trying to play dvd's or games? not all games have a dolby digital or DTS soundtrack.
  3. Pooon
    Pooon
    Dec 26, 2002
    7,354
    Canterbury, Kent
    +944
    Are you sure you have pluge the optical cable into the scocket market "optical in" and not "optical out" (if it has an optical out that is). I think you will need to select Audio 1 or Audio 2 to get the sound from your PS2, i believe you press the Function button on your remote to change inputs
