PS2 Connectivity
Bungle1
Just wondered if anyone knows the best way to get a PS2 to share a (19") screen with my computer. Do i have to buy some sort of switch box, or can I use some sort of USB connection from the PS2 to the PC.
Go gently on me, im only a newbie !!
Thanks.
T0rNaDo
both my kids do this , but there 19" monitor is a lcd tv/monitor.
has scart connection... vga, audio etc...
as to connection it to a standard vga monitor , know idea if you can,
X
xelallah
I've got the top one there that I no longer use. Can deliver it to you for £15. The unit itself comes with a european power cable (as standard), that you can use a standard shaving adaptor to convert!
