PS2 connection to TV.............
Discussion in 'Playstation Forums' started by andy_mac, Sep 19, 2001.
  1. andy_mac
    andy_mac
    Sep 17, 2001
    34
    Coulsdon
    I want to buy a high quality RGB Scart cable to connect my PS2 to my TV for the best possible picture for my games & DVDs.<br />I am going to get the DVD Region X, which will eliminate the green screen effect on DVDs, so I was thinking of getting the Official Sony RGB Scart lead as, although it is quite expensive, it is supposed to be very good.<br />Does anyone know if this is the best scart lead to buy? If not, which scart lead would you recommend?
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I read somewhere monster had released some cables for the PS2, which although expensive were supposed to be pretty good.
    You might want to see if you can find a supplier somewhere.
  3. liteon
    liteon
    Aug 23, 2001
    95
    You can get the monster cables from O'Briens hi-fi 0208 9461528. I am not sure if monster cable do a RGB lead though.
  4. AMc
    AMc
    Nov 20, 2000
    7,016
    Near Norwich
    +3,646
    Only monster cable I've seen is an S-Video lead and it was pretty pricey.<br />I bought a £5 Logic 3 S-VHS lead (their mistake its s-video) gold connectors and quite thick. Not going to set the world on fire but it's a marked improvement over the bundled composite lead if your RGB SCART is occupied.
