PS2 connection to Plasma VGA port
KevinWood
Has any tried connecting a PS2 via a VGA adaptor (I saw one in GAME for £30) to a plasma? If so was it any good?
Regards
Gant
jont
My PS2 goes through a JS RGB>VGA box and works fine ... more expensive but also feeds my sky+ into the plasma aswell ...
Jon
AOD
Umm, you probably already know this but your PS2 can output Component as well as RGB.
You might want to try it and see what the result is like.
L
lpro
What leads do I need to put PS2 through the VGA. Do I need a RGB lead??? Just got the basic PS2 leads. Sorry for being so thick.
T
TorAtle
RGB yes but with vertical and horizontal sync. I don't know if PS2 outputs those - although it is a small computer I think not.
I bought a 3Logic component cable for less than 10 pounds and the picture is brilliant.
Similar threads
