PS2 connection to 9986
Discussion in 'LCD & LED LCD TVs Forum' started by Car man sleeps, Feb 19, 2005.
Tags:
  1. Car man sleeps
    Car man sleeps
    I'm sure this is an easy one for you all :)
    what's the best way to connect a PS2 to the PF 9986?
    thanks
    Car man
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Mine's connected into the side inputs. Just Composite, but works OK. I'd quite like to know if there's a better way myself! Can the PS2 output RGB? Or component?
    Jimmy
  3. steeled
    steeled
    Apr 23, 2002
    499
    28
    Maidenhead
    +54
    The PS2 can output RGB or component (but not Progressive Scan). You just have to have the correct lead. The supplied lead just gives you composite and Left/Right audio. They normally give you and adaptor to put this into a SCART.
    Third party manufacturers make the RGB cables. QED make a nice PS2 to SCART wired for RGB.
    Component leads are very thin on the ground but can be found on the internet.
    NB: The PS2 does not output RGB or component when playing DVDs. (I think that is why you only get the composite lead as standard)
    HTH
